DOM with a field descriptor type which calls a Automation script
Solved1.38K views1st October 2024#automationscript DOM FieldDescriptor
Hari priya Venkatesan [DevOps Advocate]1.06K 26th September 2024 0 Comments
Hi Team,
I wanted to know if there is any field descriptor type in DOM which calls a Automation script. Because i want to create a form with object manager instances mapped to a module, in which one  of the field is a drop down and its values are retrieved based on logic. So is there a field descriptor which calls a AS
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 1st October 2024
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K Posted 26th September 2024 0 Comments
There is no such thing that you are describing, but you may utilize DOM Actions and DOM Buttons.
You can call an automation script by defining a new DOM action and typing in the name of the script you want to trigger in the “Script” field seen here
After that, you can define a DOM button, which can call your previously created DOM action, which will consequentially call the desired script
These buttons will be visible in the low code apps for the DOM instances in statuses you wish to have them.
You can read more about it here
