Display key case sensitivity
Solved1.52K views9th April 2024
Andrea Ivkovic [SLC] [DevOps Advocate]392 9th April 2024 0 Comments
Hi Dojo community,
Are display keys in DataMiner case-sensitive?
Andrea Ivkovic [SLC] [DevOps Advocate] Selected answer as best 9th April 2024
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 9th April 2024 1 Comment
It's not case sensitive.
When I try to retrieve a parameter value by display key from a script with or without capitals, it always returns the value properly.
Andrea Ivkovic [SLC] [DevOps Advocate] commented 9th April 2024
Hi Jochen, thank you for your answer.
