Discover Tip for UNKNOW devices in NMS / Meinberg
Solved1.47K views3rd September 2024mbgNMS meinberg NMS
Rodrigo Vivar [DevOps Member]164 3rd September 2024 0 Comments
When you launch the discover process, you can find that the devices are “unknow” devices . This a problem with the API release check
When the system discovers the devices are marked as UNKNOW.
In the Advanced options are the following conditions
With these conditions we can manage LTOS devices with API release up to 16.x so if you have a LTOS release, for example 7.08.14 has the API 17 so you must modify the CITYPE in discovery
Now launch again the Discovery process and you can see the devices
We hope that this TIP will be usefull for another issues, and will be solved in the future relase from the Skyline Team Support
Rodrigo Vivar [DevOps Member] Selected answer as best 3rd September 2024
Stijn Declerck [SLC] [DevOps Advocate]824 Posted 3rd September 2024 1 Comment
Hi Rodrigo,
Discovering a Meinberg LANTIME device running API version 17 is indeed currently not possible with the CI types included in the latest mbgNMS 1.3.0 package. Adding the proposed condition is the correct fix. It will be included in the next release of the mbgNMS package (version 1.3.1) end of September.
Rodrigo Vivar [DevOps Member] Posted new comment 3rd September 2024
Rodrigo Vivar [DevOps Member] commented 3rd September 2024
Thanks
