Disabling monitoring condition not working
Solved1.44K views20th September 2022alarm alarm template monitoring
Robin Becker [DevOps Member]1.42K 20th September 2022 0 Comments
I’m trying to disable the monitoring on the ‘Total Bitrate’ column if the column ‘Video Codec’ is set to Not initialized but I can’t get it to work. If reverse the condition (Not equal to) it does indeed disable monitoring on the first row.
Robin Becker [DevOps Member] Selected answer as best 20th September 2022
Jeroen Neyt [SLC] [DevOps Advocate]2.53K Posted 20th September 2022 1 Comment
Checking against Not Initialized is a bit of a special case and needs a different configuration. Where you selected Value, you’ll need to select Not Initialized in order for this to work.
Robin Becker [DevOps Member] Posted new comment 20th September 2022
Robin Becker [DevOps Member] commented 20th September 2022
It wasn’t more complicated than this. Thank you!
