Different Card Layouts Possible on Each Cube Side?
Solved1.82K views16th October 2024
Mark HOUSE100 16th February 2022 0 Comments
Hi - since our recent upgrade to v10.2, the operations team here have reported that it's no longer possible to have different card layouts on each of the Cube sides. For example, on the first side a proportional layout might be used, then on the second side, a workspace with a tab layout is activated. The problem reported is that the layout on the first side is now forced to a tab layout too. The team tell me this was not the case before the upgrade (each side kept its set layout). Unfortunately, I never tried this before so I can't confirm. Can anyone else comment on this?
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 16th October 2024
Pieter Van Compernolle [SLC] [DevOps Enabler]3.89K Posted 16th October 2024 0 Comments
Starting from DataMiner Cube 10.4.12, the different Cube sides will have their own 'layout' value and as such, it will be possible to have Cube side1 in tab layout and Cube side2 in proportional. If you have Cube automatic updates and your client machines have internet access, this feature will come to you automatically shortly after the release of 10.4.12 which is scheduled for Nov 15th 2024.
