Different Card Layouts Possible on Each Cube Side?
Solved2.25K views16th October 2024
Mark HOUSE100 16th February 2022 0 Comments
Hi - since our recent upgrade to v10.2, the operations team here have reported that it's no longer possible to have different card layouts on each of the Cube sides. For example, on the first side a proportional layout might be used, then on the second side, a workspace with a tab layout is activated. The problem reported is that the layout on the first side is now forced to a tab layout too. The team tell me this was not the case before the upgrade (each side kept its set layout). Unfortunately, I never tried this before so I can't confirm. Can anyone else comment on this?
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 16th October 2024
Marc Barthel15 Posted 26th January 2024 0 Comments
Dear Pieter and Ronny. I have created a request
Ability to have different layout settings for different cubes sites
Marc Barthel Edited answer 26th January 2024
