Delete resources using automation script
Solved1.50K views14th August 2024#automationscript #DeleteResources DataMiner resources
Hari priya Venkatesan [DevOps Advocate]1.06K 18th June 2024 0 Comments
As per the attachment, under the apps tab ---> Resources, i want to delete certain resources that are associated with the Sources pool using automation script. Is that possible to do? How can that be done?
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 14th August 2024
Pieter Carlu [SLC] [DevOps Advocate]315 Posted 18th June 2024 0 Comments
You can do this by first getting the resources in that pool and then deleting them. Do note that if those resources are in use by bookings, traceData will be thrown.
var helper = new ResourceManagerHelper(_engine.SendSLNetSingleResponseMessage);
var resources = helper.GetResources(ResourceExposers.PoolGUIDs.Contains(Guid.Parse("Insert PoolGUID here")));
helper.RemoveResources(resources);
You will also have to add a using statement for Skyline.DataMiner.Net.Messages and Skyline.DataMiner.Net.Messages.SLDataGateway.
