Dataminer Integration with Synamedia/Cisco control systems (Rosa VSM and Cisco PNC)
Solved3.22K views8th February 2021Cisco PNC RosaVSM Synamedia vDCM
Paula Alves [DevOps Member] 22nd January 2021 0 Comments
Hi all,
Does anyone have the experience or know a use case for:
  • monitoring vDCM equipment via Rosa VSM (compression system)
  • monitoring DCM/PCAM via Cisco PNC (encryption system)
Thanks in advance
Paula Alves [DevOps Member] Selected answer as best 8th February 2021
Dominique De Paepe [SLC] [DevOps Advocate]216 Posted 1st February 2021 1 Comment
Hi Paula,
Glad to confirm myself to have assisted a project related to the integration of vDCM in DataMiner over ROSA VSM in the context of DTT/DTH platform.
Related to the DCM integration over PNC, while glad to confirm our catalog to show a PNC driver, I could not identify the context within this one was made available.
Given the info as shared above and added the commitment from Skyline to the unconditional integration of all functions regardless the protocol that is required, I hope you can be confident that Skyline can support you in this area also. But if not yet, please do not hesitate to come back to us here.
Best regards
Dominique
Paula Alves [DevOps Member] Posted new comment 8th February 2021
Paula Alves [DevOps Member] commented 8th February 2021
Hi Dominique,
Thanks for the information.
Best Regards,
Paula
