Dataminer Cube and HTTPS communications
Solved2.92K views12th February 2024Cube HTTPS
Phillip Choi56 2nd January 2024 0 Comments
How can you confirm if the cube communicates to the Dataminer using HTTPS other than a Wireshark capture? Are there any indicators within the cube application to show this? Is it normal for me to see POSTS in HTTP?
POST /SLNetService HTTP/1.1
User-Agent: Mozilla/4.0+(compatible; MSIE 6.0; Windows 10.0.19045.0; MS .NET Remoting; MS .NET CLR 4.0.30319.42000 )
Content-Type: application/octet-stream
Host: x.x.x.x:8004
Content-Length: 1042
........................HandleMessages.kSkyline.DataMiner.Net.ISLNet, SLNetTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12......... .... .........MSLNetTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12......Skyline.DataMiner.Net.Security.ConnectionToken....
_connectionID._token._seqID....System.Guid............System.Guid....._a._b._c._d._e._f._g._h._i._j._k.......................f..P9.@.Z}$.<.. .......................)Skyline.DataMiner.Net.Messages.DMSMessage.... ...............M.......5Skyline.DataMiner.Net.Messages.Advanced.ZippedMessage....
ZippedData...... ..............PK........
V"X._.-1...........data.RMK.@.M....M<.!7)...A
$.4.ES..^D.&.JH.-......;m...........[f.UQ./i....d.....I...7_......9..7..\....JQ..o..(O...&...k......_...Y...[.]..Y....G.... ....s:.N<?..(...A.0...y.P.O...C.3^gtY{......,.oi..lz.B..:.n....D....<v.)c.,{.Nj..j.[*G=....u+ i.{.._........G.N.x.y a.......H.mT7i.;.......5.`...4.dC~d...@...PK..3.......
V"X._.-1.........................dataPK..........2...S.....
Nils Hoven [DevOps Advocate] Answered question 12th February 2024
Nils Hoven [DevOps Advocate]1.79K Posted 12th February 2024 0 Comments
Hi Phillip,
my experience is that if you don't have gRPC enabled and still use .NET Remoting, you can easily see this in the "About" window in Cube ("connection" tab):
When gRPC is enabled, you see something different then the (Legacy)RemotingConnection shown above.
Hope this helps!
BR
Nils
