Create DomInstance with default values
Solved1.32K views7th April 2023DOM
8
Thomas Cauwelier [SLC] [DevOps Advocate]1.87K 6th April 2023 0 Comments
I noticed that default values are not applied to fields when creating a DomInstance via code.
Do we have a method available that can do this?
I did not find one, so I was already writing something like this:
Thomas Cauwelier [SLC] [DevOps Advocate] Selected answer as best 7th April 2023
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 7th April 2023 0 Comments
Hi Thomas, As you have indeed noticed, there is no automated way of assigning these default values to a DomInstance. The default values defined on a FieldDescriptor are currently only used by the form component in a low-code app to pre-fill some values for you. It is indeed also possible to extract this value and apply it to your DomInstance in code. The code snippet you posted seems to do that job perfectly.
