Correlation Rules, Old Engine
Solved2.06K views22nd June 2022Correlation old engine
Manuel Gallardo [DevOps Advocate]769 20th January 2022 0 Comments
I need to migrate correlation rules between two DMS. I can see the new rules in the Correlation folder but not the old engine rules, where are they located?
Thanks in advance!
Manuel Gallardo [DevOps Advocate] Selected answer as best 22nd June 2022
Manuel Gallardo [DevOps Advocate]769 Posted 21st January 2022 0 Comments
Thank you both!
Manuel Gallardo [DevOps Advocate] Answered question 21st January 2022
