Correlation Rules, Old Engine
Solved2.07K views22nd June 2022Correlation old engine
Manuel Gallardo [DevOps Advocate]769 20th January 2022 0 Comments
I need to migrate correlation rules between two DMS. I can see the new rules in the Correlation folder but not the old engine rules, where are they located?
Thanks in advance!
Manuel Gallardo [DevOps Advocate] Selected answer as best 22nd June 2022
Pieter-Jan Vuylsteke [SLC] [DevOps Member]332 Posted 20th January 2022 0 Comments
Hi Manuel, the old engine rules are located in the Brain.xml file which you can find in the C:\Skyline DataMiner\ folder.
Hope this helps!
