ConnectAppAndInfoUsingTicket – how to get value for connection ticket
Solved640 views18th August 2025APIv1 login
Tim Vandenbruwaene [SLC] [DevOps Member]2.24K 18th August 2025 0 Comments
In "api/v1/Soap.Asmx?op=ConnectAppAndInfoUsingTicket" it mentions you can connect using a connection ticket.
(<connectionTicket>string</connectionTicket>)
How/where can I get the value for the connectionticket?
Tim Vandenbruwaene [SLC] [DevOps Member] Selected answer as best 18th August 2025
Tom Van Bruaene [SLC] [DevOps Member]913 Posted 18th August 2025 0 Comments
If you already have an existing WebApi connection you can use: RequestLoginAsTicket | DataMiner Docs
If you have a regular connection you can use RequestTicketMessage
An example of how that's used can be found here:
SLC-LCA-GQIMonitor/GQIMonitorExtensions/GQIMonitor_1/ApplicationsFetcher.cs at 1eb8f53ab2b53cc0ab79ac2942eca01db53e534a · SkylineCommunications/SLC-LCA-GQIMonitor
