Concatenate input data with fixed data to pass to GQI input arguments in LCA
Solved1.15K views20th March 2025adhoc datasource GQI LCA
Matthijs Favorel [SLC] [DevOps Advocate]2.63K 19th March 2025 0 Comments
I have a text input field in my LCA that the user needs to fill in. This is a name of a file.
I also have a custom GQI datasource that needs the full path to this file, for example "c:\[User Input].txt". This path could be hard coded in the app.
Is there any way I can make this full path to pass it to the datasource?
I would rather not change my datasource as it's a generic one.
I would also rather not have the user input the full path, as the name will be used on other places in the app as well.
Matthijs Favorel [SLC] [DevOps Advocate] Selected answer as best 20th March 2025
Gilles Bara [SLC] [DevOps Advocate]7.27K Posted 19th March 2025 0 Comments
Doing this purely inside the low-code app is not possible, yet. However, this functionality is coming up, as part of an extension of flows. A new flow operator (of which the name is not decided yet) should allow you to transform any data stream into another. In this case you want to transform a text into another text.
