Clone an element with all settings
Solved2.61K views12th January 2024clone elements
Gerwin van der Kamp [DevOps Advocate]4.09K 9th January 2024 0 Comments
Is there a way to make an identical copy of an element with only another name. This element is using connection strings which makes it probaly tricky to do this.
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 12th January 2024
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K Posted 10th January 2024 0 Comments
I think you might want to generate an active backup element.
The DELT is probably the best approach but just to give you another option.
What you also could do is duplicate the element and use Copy Element Data | DataMiner Docs to get all the data from the original element. And past it to the second one (also explained in the article). Then it's just a matter of setting up the element connections manually again and you would be good to go.
Note that this approach is a hard set. This means that the connector might not behave completely as you would expect it. eg you have login credentials, a login button and a login status, when you apply the data from one element to another it will copy over the credentials and the login status but the button would not be pressed. This means that the status might state "Connected" while the command hasn't actually been send. So you might want to restart the element afterwards to update those settings.
Either way it's a bit risky so best to test this out in a demo environment.
