Clear parameter values on Tables
Solved1.43K views27th May 2025driver option protocol.leave SetParameterDescription
Jose Araujo [DevOps Advocate]1.01K 25th May 2025 0 Comments
Hi
I need to clear table 1100 — that is, delete all its values.
I tried running this QAction, but it didn't work.
1100 is table
1001 is parameter
1002 is parameter
1003 is parameter
1004 is parameter
(This part of QAction delete table)
object[] columnClearInfo = { 1100, 1101, 1102, 1103, 1104 };
object[] columnClearValues = {
newobject[0], // PK
newobject[0], // UUID
newobject[0], // Name
newobject[0], // State
newobject[0], // Chunking
protocol.NotifyProtocol(220, columnClearInfo, columnClearValues);
<Paramid="1101">
<Name>ServiceTableUUID</Name>
<Description>UID</Description>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1102">
<Name>ServiceTableService</Name>
<Description>Service Name</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1103">
<Name>ServiceTableStateService</Name>
<Description>Service Status</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1104">
<Name>ServiceTablechunk</Name>
<Description>Chunk</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1100"trending="true">
<Name>ServiceTable</Name>
<Description>Table Of Services</Description>
<Type>array</Type>
<ArrayOptionsindex="0"options="key" >
<ColumnOptionidx="0"pid="1101"type="retrieved"options=";save" />
<ColumnOptionidx="1"pid="1102"type="retrieved"options=";save" />
<ColumnOptionidx="2"pid="1103"type="retrieved"options=";save" />
<ColumnOptionidx="3"pid="1104"type="retrieved"options=";save" />
</ArrayOptions>
<Information>
<Subtext>
<![CDATA[Table Of Services]]>
</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Services</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Typeoptions="tab=columns:1101|0-1102|1-1103|2-1104|3,width:350-220-112-100,sort:STRING-STRING-STRING-STRING,lines:10,filter:true">table</Type>
</Measurement>
</Param>
Jose Araujo [DevOps Advocate] Selected answer as best 27th May 2025
Tiago Pina [SLC] [DevOps Member]476 Posted 25th May 2025 1 Comment
Hi Jose
When you want to clear an entire table, the most efficient approach is to use the clear action in the XML. This way, you don't need to retrieve all the keys in the QAction; you simply execute protocol.CheckTrigger(Id)
Regards
Jose Araujo [DevOps Advocate] Posted new comment 26th May 2025
Jose Araujo [DevOps Advocate] commented 26th May 2025
Hi Tiago,
I use this in my Qaction before fill columns
protocol.CheckTrigger(1100); //table
protocol.CheckTrigger(1101); //parameter1
protocol.CheckTrigger(1102); //parameter2
protocol.CheckTrigger(1103); ////parameter3
And in my XML
<Action id="9">
<Name>services</Name>
<On id="21">parameter</On>
<Type>clear</Type>
</Action>
But didn't work, when QAction is running add new line but no clean my table.
