CI/CD Documentation Deployment on Multi-Agent DataMiner System
Solved353 views5th March 2026CICD
Kévin Dugué [DevOps Advocate]702 8th January 2026 0 Comments
Hi everyone,
I’m looking for some guidance or best practices regarding CI/CD deployment of documentation in a multi-agent DataMiner system.
Context
I have set up a CI/CD pipeline that generates a documentation package and deploys it to DataMiner.
The documentation is deployed to the following path on the system:
C:\Skyline DataMiner\Webpages\Documentation
To achieve this, I am using:
  • AppInstaller class with CompanionFiles
  • Skyline.DataMiner.CICD.Tools.Packager
  • Skyline.DataMiner.CICD.Tools.CatalogUpload
  • Skyline.DataMiner.CICD.Tools.DataMinerDeploy
From a pipeline perspective, everything works as expected:
  • The package is created correctly
  • The documentation is installed successfully
  • The files appear under Webpages\Documentation
Problem
The issue arises because the DataMiner System contains two DMA pairs (Main/Backup).
When the deployment runs The documentation is deployed only on one agent
Questions
I would like to know:
  • Is there a supported way to force the deployment of my package to all agents in a DataMiner System
  • Is there a configuration option in tools/AppInstaller that forces synchronization between agents?
Any insights, best practices, or confirmations on expected behavior would be greatly appreciated.
Thanks in advance!
Kévin Dugué [DevOps Advocate] Selected answer as best 5th March 2026
Pieter Van Compernolle [SLC] [DevOps Enabler]3.80K Posted 9th January 2026 2 Comments
Hi Kévin,
Is it an option to move your webpages into WebPages/Public/Documentation? As of 10.5.10 (RN43458), the WebPages/Public folder is allowed and supported in our companion files and should be syncing well in the cluster.
Kévin Dugué [DevOps Advocate] commented 12th January 2026
Hi Pieter,
I manually placed a file in the "WebPages/Public/Documentation" folder, but I still have to wait for midnight synchronization. Is there a way to force synchronization in C#? But it's better than nothing, thank you.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 12th January 2026
Hi Kévin,
You can trigger the sync manually, see https://docs.dataminer.services/dataminer/Administrator_guide/DataMiner_Systems/DMS_maintenance_tools/Synchronizing_data_between_DataMiner_Agents.html. If it's just one file, you can choose 'File' in the dropdown box, in case it's a whole bunch of files, you can select 'this agent' (be sure to be connected to the agent that has the files already.
