Check if element is active using GQI
Solved1.32K views18th November 2024ActiveElement GQI LCA
Hari priya Venkatesan [DevOps Advocate]1.06K 18th November 2024 0 Comments
Hi Team,
I'm trying to check if an element is active or not using dms send message in adhoc GQI.
Is it possible to get that info?
Thanks
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 18th November 2024
Tom Waterbley [SLC] [DevOps Enabler]10.21K Posted 18th November 2024 0 Comments
Hi, if the method proposed by Miguel doesn't work in your case, you could use GetElementByIDMessage or GetElementByNameMessage in your ad-hoc data source to retrieve the information.
var elementInfo = dms.SendMessage(new GetElementByIDMessage(agentID, elementID)) as ElementInfoEventMessage;
var isActive = elementInfo.State == ElementState.Active;
The dms object can be retrieved in the OnInit() method:
public OnInitOutputArgs OnInit(OnInitInputArgs args)
dms = args.DMS;
return new OnInitOutputArgs();
