Character/string length validation for parameter
Solved2.35K views2nd August 2024length parameter validation
Daniel Zank [DevOps Advocate]313 31st July 2024 0 Comments
Hi Dojo!
We would like to check the entered character length (minimum length/maximum length) before passing a parameter to an element. Is there any way to do this directly in Visio or do I have to go the detour via an automation script?
Thanks for your answer and suggestions!
Daniel
Daniel Zank [DevOps Advocate] Answered question 2nd August 2024
Daniel Zank [DevOps Advocate]313 Posted 2nd August 2024 0 Comments
