Changing name of main connection in element wizard
Solved1.54K views23rd October 2023change main connection name portsettings
8
Matej Plakalovic [SLC] [DevOps Member]696 23rd October 2023 0 Comments
Hi Dojo Community,
I received a request to change the name of the main connection in the element wizard. I remember adding (and changing) the name(s) of additional connection(s) for previous tasks, but I have never done so for the main connection...
Does anyone know if it's actually possible to change the name of main connection? Or this is only possible for additional connections ...
Here are the changes I've made, but with no desired outcome and results:
P.S. DMA Version is 10.3.0.0-13088-CU4;
Matej Plakalovic [SLC] [DevOps Member] Selected answer as best 23rd October 2023
Thomas Cauwelier [SLC] [DevOps Advocate]1.86K Posted 23rd October 2023 1 Comment
Hi Matej,
It is not possible to change the name of the main connection.
The names are hard-coded in Cube, and are chosen based on the connection type.
You can only change the name of the additional connections.
Matej Plakalovic [SLC] [DevOps Member] commented 23rd October 2023
Thank you Thomas 😀
