Changing name of main connection in element wizard
Solved1.43K views23rd October 2023change main connection name portsettings
8
Matej Plakalovic [SLC] [DevOps Member]696 23rd October 2023 0 Comments
Hi Dojo Community,
I received a request to change the name of the main connection in the element wizard. I remember adding (and changing) the name(s) of additional connection(s) for previous tasks, but I have never done so for the main connection…
Does anyone know if it’s actually possible to change the name of main connection? Or this is only possible for additional connections …
Here are the changes I’ve made, but with no desired outcome and results:
P.S. DMA Version is 10.3.0.0-13088-CU4;
Matej Plakalovic [SLC] [DevOps Member] Selected answer as best 23rd October 2023
Thomas Cauwelier [SLC] [DevOps Advocate]1.86K Posted 23rd October 2023 1 Comment
Hi Matej,
It is not possible to change the name of the main connection.
The names are hard-coded in Cube, and are chosen based on the connection type.
You can only change the name of the additional connections.
Matej Plakalovic [SLC] [DevOps Member] commented 23rd October 2023
Thank you Thomas 😀
