Can you lock parameters for an element?
Solved2.82K views14th November 2022data IGMP locking Parameters
Stacey Taplin42 14th November 2022 0 Comments
Hello,
We are wondering if there is a way to lock a parameter such as the one below. Reason being we do not want it being accidently disabled by other admin users and general users. We always want it enabled, and for only certain people to be able to even be able to press the button here that would disable it.
Kind regards,
Stacey
Stacey Taplin Selected answer as best 14th November 2022
Gerwin van der Kamp [DevOps Advocate]4.09K Posted 14th November 2022 0 Comments
If you don't want or can't lock an complete element, then you might try to alarm that parameter, and then either have an user react to it or trigger an correlation rule that will switch it back to the desired state.
