C# API connection using proxy
Solved3.59K views28th February 2023proxy
11
David Joseph [SLC] [DevOps Member]417 27th February 2023 0 Comments
From a Dataminer installed on an internal network at a customer we need to do an API call to a cloud application. There is no direct access from this server, so a proxy server has been set up in the middle to make the communication possible. This has been setup as a default proxy on the windows machine. When testing this API access via the browser or via postman from this machine, the API call works (by passing via the configured proxy), no need to configure anything on browser level or in Postman. However when doing the call from automation using HttpClient the proxy is not used. The only way to make it work it seems is to hardcoded the proxy in the automation script as follows:
Is there another way to make sure the httpClient use the system configured proxy without hardcoding this using a proxy in the script ?
David Joseph [SLC] [DevOps Member] Selected answer as best 28th February 2023
Jeroen Neyt [SLC] [DevOps Advocate]2.61K Posted 27th February 2023 0 Comments
The reason why this works out of the box in Postman and the browser is because those processes will be running as the user who has the proxy settings configured in Windows.
SLAutomation (and as a result all your automation scripts) run as the  NT_AUTHORITY/SYSTEM user. One of the ways to avoid having to configure the proxy server details in your script would be to configure them on that user in Windows similar like how it was already configured on that other user.
How to set up a proxy for Local System account at the machine level describes how you can easily set this up.
After having configured those settings, HttpClient will use those by default, so you can just do the following:
var client = new HttpClient();
var response = client.GetAsync("https://community.dataminer.services");
And the request will be sent through the proxy.
