Building Solution which is using DIS 2.35.1.33 creates error
Solved2.01K views5th January 2022build error DIS
Ladan Razeghi [DevOps Catalyst]1.09K 5th January 2022 0 Comments
Building Solution which is using DIS 2.35.1.33 creates below error. Although Validation is clear and protocol can be deployed successfully in DM.
"Error CS1061 'ElementPortInfo' does not contain a definition for 'IsSslTlsEnabled' and no accessible extension method 'IsSslTlsEnabled' accepting a first argument of type 'ElementPortInfo' could be found (are you missing a using directive or an assembly reference?)"
Ladan Razeghi [DevOps Catalyst] Selected answer as best 5th January 2022
Tom Waterbley [SLC] [DevOps Enabler]10.21K Posted 5th January 2022 3 Comments
Hi Ladan, the IsSslTlsEnabled property was added to the ElementPortInfo class in DataMiner version 10.0.1.0 (see RN22873). DIS is using the DLL files from the local DataMiner installation to compile the code in Visual Studio. Could it be that you're local DMA is running on an older version?
Reza Biglari [DevOps Member] Edited comment 7th January 2022
Ladan Razeghi [DevOps Catalyst] commented 5th January 2022
Thank you Tom for your reply. Yes our local Dataminer is 9.6.10.0. Will using this version of DIS cause issues on DMAs which runs on version 9.6? Currently only our cloud DMAs are on version 10. Is there any place which we can check this information before upgrading to new version of DIS?
Tom Waterbley [SLC] [DevOps Enabler] commented 6th January 2022
DataMiner and DIS are two separate things. Updating DIS won’t change the DataMiner installation.
However, if the “IsSslTlsEnabled” property is being used in a driver, that driver will only work on DataMiner installations with version 10.0.1 or higher.
Reza Biglari [DevOps Member] commented 7th January 2022
There appears to be a bigger problem other than references to IsSslTlsEnabled for 9.6 users. With the new DIS, it is not able to generate QAction63000 any longer.
https://community.dataminer.services/question/dis-2-35-1-33-can-no-longer-auto-generate-code-into-qaction-63000/
Could you suggest a fix for this?
Edit: This is now resolved. Please refer to resolution on question linked above for further details.
