Best way to submit fixes in connectors
Solved1.90K views29th January 2025bug fixing Connector Q&A
Gerwin van der Kamp [DevOps Advocate]4.12K 28th January 2025 0 Comments
I've found a small issue in an connector, and fixed that localy, how can i submit this version so that i can run through SLC Q&A and released as an signed version?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 29th January 2025
Patricia Pereira [SLC] [DevOps Member]139 Posted 28th January 2025 2 Comments
Hi Gerwin,
According to: Protocols | DataMiner Docs you should request this to your Technical Account Manager.
Kind regards.
Patricia Pereira [SLC] [DevOps Member] Posted new comment 29th January 2025
Gerwin van der Kamp [DevOps Advocate] commented 29th January 2025
I was just hoping on some more elegant way to handle code sharing. (gitlab/github)
Patricia Pereira [SLC] [DevOps Member] commented 29th January 2025
I'm not sure, but this link might be helpful: https://docs.dataminer.services/user-guide/Cloud_Platform/Catalog/Tutorials/Tutorial_Register_Catalog_Item.html . But you might want to ask guidance from the account manager as my knowledge on the subject is very limited.
