Automation Script with Execution Duration
Solved1.34K views8th January 2025
6
Ashwiny J K Anandan [DevOps Advocate]578 6th January 2025 0 Comments
I have created 3 automation scripts and it should execute one by one accordingly:
  1. Execute Script 1
  2. Wait 15 seconds and execute Script 2
  3. Wait for 2 minutes and execute Script 3
How can i create the duration between the script execution? I plan to tie the scripts to a visual (Visio), making it a one-click solution for the operator
Appreciate your advise.
Thank you.
Ashwiny J K Anandan [DevOps Advocate] Selected answer as best 8th January 2025
Ashwiny J K Anandan [DevOps Advocate]578 Posted 6th January 2025 1 Comment
Hi Joao, kindly refer to the pictures below. TQ
João Severino [SLC] [DevOps Enabler] Posted new comment 6th January 2025
João Severino [SLC] [DevOps Enabler] commented 6th January 2025
Please see the edit on my original answer
