Automation script SLProtocol issue
Solved2.07K views17th February 2023Automation engine InterApp NuGet SLProtocol
6
Andries Deklerck [SLC] [DevOps Member]492 17th February 2023 1 Comment
Can I use a NuGet (EvsCerebrum.InterappAPI) that has both SLProtocol and Engine in an automation script?
In my automation script, I have below exception.
The type ‘SLProtocol’ is defined in an assembly that is not referenced. You must add a reference to assembly ‘SLManagedScripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null’.
These are the NuGets I use in my automation script.
Andries Deklerck [SLC] [DevOps Member] Selected answer as best 17th February 2023
Andries Deklerck [SLC] [DevOps Member] commented 17th February 2023
I moved everything related to Engine to another class in the NuGet and now it works.
Andries Deklerck [SLC] [DevOps Member]492 Posted 17th February 2023 0 Comments
Introducing a new class tailored to the Engine solved the problem.
Changed:
public class EvsCerebrumClient
private readonly SLProtocol protocol;
private readonly Engine engine;
public EvsCerebrumClient(SLProtocol protocol)
this.protocol = protocol;
public EvsCerebrumClient(Engine engine)
this.engine = engine;
To:
public class EvsCerebrumEngineClient
public EvsCerebrumEngineClient(Engine engine)
