Automation Script Fail
Solved1.06K views14th March 2024#automationscript automation engine automation scripts
Steve Kasir172 14th March 2024 0 Comments
I have an automation script that tries to set 2 parameters. The script successfully sets one parameter but then thinks it fails so then it doesn’t move on to finish the automation script and i get an error which is shown in the picture.
Is there anyway to stop automation from terminating the script if it cant verify the set worked? And if not is this a driver level issue where some data received back after the set cant be validated?
Steve Kasir Selected answer as best 14th March 2024
João Severino [SLC] [DevOps Enabler]14.48K Posted 14th March 2024 0 Comments
Hi Steve,
You should be able to set the execution options of your script to not check the read parameter by unchecking the following option
Reference: Script execution options | DataMiner Docs
Or in code, you can use the Method SetFlag | DataMiner Docs with the flag NoCheckingSets (reference: Enum RunTimeFlags | DataMiner Docs)
