Automation example in documentation fails to run; SubScriptOptions : SelectMemory
Solved3.10K views21st April 2022Automation script ScriptMemory
Data Miner63 12th April 2022 0 Comments
Copy the example code to the dot from documentation (also below) for SubScriptOptions:SelectMemory(String, ScriptMemory) and then run it raises Script Execution Failure.
How to get this method to work please? Observed in DataMiner 10.1
Script Failure (myParentScript): (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript 'myParentScript' Failed: 0x80004005
at CManagedAutomation.RunWrapped(CManagedAutomation* , Int32 iCookie, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* pvarReturn, String scriptName)
at CManagedAutomation.Run(CManagedAutomation* , Int32 iCookie, Char* bstrScriptName, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* varEntryPoint, tagVARIANT* pvarReturn) (CSharp; 0x80131500h): (see comment for more details)
Script Failure (mySubScript): (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Get Memory Position 'subscriptMemory':1 Failed: 0x80004005
Class SubScriptOptions | DataMiner Docs
Selects a script memory from the main script to be used as the script memory in the subscript.
Examples
Main script:
<code class="hljs stata"><span class="hljs-keyword">var</span> <span class="hljs-keyword">memory</span> = engine.GetMemory(<span class="hljs-string">"parentMemory"</span>);	<span class="hljs-comment">// The parent script has a script memory with name "parentMemory".</span>
<span class="hljs-keyword">memory</span>.<span class="hljs-keyword">Set</span>(1, <span class="hljs-string">"MyValue"</span>);	<span class="hljs-comment">// The first entry of this memory is set to the value "MyValue".</span></code>
var subscript = engine.PrepareSubScript("MySubscript");
</code>
<span class="hljs-selector-tag">subscript</span><span class="hljs-selector-class">.SelectMemory</span>(<span class="hljs-string">"subscriptMemory"</span>, memory); <span class="hljs-comment">// The subscript has a script memory with name "subscriptMemory" and this memory will be linked to the parent memory.</span>
<span class="hljs-selector-tag">subscript</span><span class="hljs-selector-class">.StartScript</span>();
Sub-script:
<code class="hljs stata"><span class="hljs-keyword">var</span> <span class="hljs-keyword">memory</span> = engine.GetMemory(<span class="hljs-string">"subscriptMemory"</span>);
engine.GenerateInformation(Convert.<span class="hljs-keyword">ToString</span>(<span class="hljs-keyword">memory</span>.<span class="hljs-built_in">Get</span>(1))); <span class="hljs-comment">// This will generate an information event with value: "MyValue".</span></code>
Thomas Ghysbrecht [SLC] [DevOps Enabler] Answered question 21st April 2022
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 21st April 2022 1 Comment
Hi, That 'SubScriptOptions.SelectMemory(String, ScriptMemory)' method is unfortunately only compatible with persistent memory files. The underlying logic just calls the 'SubScriptOptions.SelectMemory(String, String)' method where the 'LinkedFile' property of the given 'ScriptMemory' is used for the second argument.  I have updated the documentation to reflect this.
Data Miner Posted new comment 24th April 2022
Data Miner commented 24th April 2022
Thank you Thomas.
