Automation – DOM Helper – Editing exising GenericEnumFieldDescriptor values?
Solved1.70K views26th October 2023Automation DOM domhelper
Rui Camacho [SLC] [DevOps Member]164 26th October 2023 0 Comments
Im trying to populate an existing GenericEnumFieldDescriptor with ALL countries:
For obvious reasons, I’d like to automate this using the DomHelper, by passing Module, SectionDefinitionID and FieldDescriptorID as arguments.
However, fetching existing SectionDefinitions or FieldDescriptors return immutable objects. So I can’t change them.
It seems I have to create the entire section from scratch using a CustomSectionDefinition?
I could re-create the existing Section by copy and add the GenericEnumFieldDescriptor Values on top, and replace it with the original Section. But this seems inadequate for the current use case.
Any ideas?
Rui Camacho [SLC] [DevOps Member] Selected answer as best 26th October 2023
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 26th October 2023 0 Comments
Hi Rui,
For DOM, it is safe to just cast the ‘SectionDefinition’ to a ‘CustomSectionDefinition’. That way you will have access to the methods for adding extra FieldDescriptors.
