Automation C# code to Comment Alarm without Acknowledging it
Solved1.14K views8th May 2025
Peter Geivaerts [DevOps Advocate]308 7th May 2025 0 Comments
What is the preferred way to put a comment in an alarm without acknowledging it from an Automation Script?
I remember I saw something similar with Engine.SLNet.SendMessage(SetAlarmStateMessage)
Can’t find any info about this in the docs.
Peter Geivaerts [DevOps Advocate] Selected answer as best 8th May 2025
Robbe De Ghein [SLC] [DevOps Advocate]1.36K Posted 8th May 2025 0 Comments
Hi Peter,
The reason it didnt work with the alarmTreeID overload is because the Info property was not set. This still necessary for legacy reasons.
This should do the trick:
var comment = “Hello world”;
engine.GetUserConnection().HandleSingleResponseMessage(new SetAlarmStateMessage(new AlarmTreeID(1, 2, 3), AlarmUserStatus.Comment, comment)
Info = new SA(new string[] { “-1”, comment }),
Peter Geivaerts [DevOps Advocate]308 Posted 8th May 2025 0 Comments
After a lot of trial and error I found a working solution
SetAlarmStateMessage sam = new SetAlarmStateMessage();
sam.AlarmId = rootAlarmID;
sam.DataMinerID = dmaID;
sam.State = 5; // 2= acknowledge alarm 5= comment
sam.Info = new SA(new string[] { “-1”, comment });
engine.SendSLNetMessage(sam);
what Didn’t seem to work:
A:
SetAlarmStateMessage sam = new SetAlarmStateMessage(tree, AlarmUserStatus.Comment, comment);
comment);
B:
SetAlarmStateMessage sam = new SetAlarmStateMessage(dmaID, alarmID, 5, comment);
Is there a reason that the use of alarmTreeID (with rootAlarmID) doesn’t work?
tested on DataMiner (10.5.0.0-15683-CU2) and use of Skyline.DataMiner.Dev.Automation 10.5.0.2
Peter Geivaerts [DevOps Advocate] Answered question 8th May 2025
