Appear Platfrom 1.2.4.23 – changing preffered source from DataMiner level
Solved1.23K views12th September 2024AppearX20 dashboard button DataMiner Cube
Adrian Marcak158 6th September 2024 0 Comments
in AppearTV X20 Platform there is a Preferred source option with which you can set the appropriate multicast on Appear:
I tried to change the preffered source using dataminer, but the fields found in DMA have the status N/A, and the parameters from wrtie are also empty:
There is only active source, which displays correctly and allows you to identify the currently active preffered source, but I couldn’t find it in the driver as write:
Is there an option to set active source with DMA? I wanted to make a simple button on the dashboard that would change the source. Thank you in advance for your help.
BR,
Adrian
Adrian Marcak Selected answer as best 12th September 2024
Robin Meurisse [SLC] [DevOps Advocate]1.48K Posted 6th September 2024 0 Comments
Hi Adrian,
The option to change the preferred source for the redundancy settings has been added in a later version.
I notice you are currently running version 1.2.4.23 where this functionality was not fully present yet, would it be possible to upgrade to version 1.2.4.32? AppearTV X20 Platform | Catalog (dataminer.services)
The latest version should allow you to edit the preferred source.
Kind regards,
