Alarm Condition on Display Key not working on VB Probe element
Solved1.63K views9th January 2025alarm BridgeTech condition VB Probe
Nick Chirumbolo [DevOps Advocate]1.04K 8th January 2025 0 Comments
This seems to only be affecting a specific element on our system (Protocol: Bridge Technologies VB Probe Series, v1.2.0.24). But when using an Alarm Condition for this element, it doesn't work if the condition is referencing a Display Index column (I've confirmed it works on several other columns, including the Primary Index).
Is this a bug, or is there something special about Display Indexes? Or could it be because of the special characters in the VB Probe index (:/-)?
To illustrate here are the settings that don't work:
And these settings do work:
Nick Chirumbolo [DevOps Advocate] Selected answer as best 9th January 2025
Simon Vandamme [SLC] [DevOps Advocate]1.02K Posted 9th January 2025 4 Comments
Hi Nick,
On top of what Catarina mentioned, I'm wondering if there is any reason why you are making use of a condition in order to filter on DisplayKey? Indeed, filtering on DisplayKey is typically done via following filter feature:
Simon Vandamme [SLC] [DevOps Advocate] Posted new comment 10th January 2025
Simon Vandamme [SLC] [DevOps Advocate] commented 9th January 2025
To have no misunderstanding, I'm not saying filtering on DisplayKey via condition is wrong. It's perfectly fair from you to expect it to work and it still makes sense for you to raise a ticket for this, thanks for that. I'm just here proposing a (potentially somewhat more natural?) alternative.
Nick Chirumbolo [DevOps Advocate] commented 9th January 2025
It's because this is an exclusion/negative filter (i.e. Ignore alarms on devices with the word TEST in their DisplayKey). Is there a way to accomplish this using that field? We'd actually prefer to use this method.
Ah just found it, I thought I had tried this and it didn't work, but maybe I did something wrong because it's working now!
https://docs.dataminer.services/user-guide/Basic_Functionality/Protocols_and_templates/Alarm_templates/Configuring_alarm_templates/Configuring_normal_alarm_thresholds.html#configuring-alarm-thresholds-for-dynamic-table-parameters
Simon Vandamme [SLC] [DevOps Advocate] commented 10th January 2025
Perfect! Thank you for providing the appropriate DataMiner Docs link
