Adhoc datasource wont load assembly
Solved1.16K views5th June 2025adhoc
Gerwin van der Kamp [DevOps Advocate]3.74K 5th February 2025 0 Comments
I created an adhoc datasource using an internal nuget.
When loading i get the following error:
Error trapped: Error thrown in implementation of GetNextPage: Could not load file or assembly 'DataMiner.DOM, Version=1.1.24.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
I found this question around this topic, so i moved the dll to the files directory but i still get this error.
It's giving this error on at least versions 10.4.10.0-14882 & 10.4.5.0-14239
Any advice?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 5th June 2025
Gerwin van der Kamp [DevOps Advocate]3.74K Posted 5th June 2025 0 Comments
Figured it out:
The DLL needs to be in the /Files folder, not in an subfolder in /Files
