Add and Update Element Properties using IDms
Solved2.25K views29th March 2024Connector element properties IDms QAction
Thomas Remmery [SLC] [DevOps Advocate]957 25th July 2023 0 Comments
I need to manipulate Element Properties from code.
I need to add a property to elements that don't have it, and I need to update the value of the property if it wouldn't be correct. I'm using the IDms classes for this from a connector QAction.
I'm able to create the property using IDms.CreateProperty() and assign it to a new element by using a notify call to create it. However most of the element properties seem to be read only when using IDms.
Is IDms able to assign/update element properties?
Tom Waterbley [SLC] [DevOps Enabler] Answered question 29th March 2024
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 29th March 2024 0 Comments
Hi Thomas,
Based on this question and other feedback, we decided to make setting properties on elements, services and views a bit more intuitive. The property objects now contain IsWritable and AsWritable methods, which replace the cast to IWritableProperty. This has been implemented in version 1.1.1.8 of the DMS library.
