Access using DIS to remote DMA through corporate VPN
Solved2.42K views17th March 2021DIS
Jack Perrott-Webb52 11th March 2021 0 Comments
We currently have to access our DMAs through our corporate VPN. We believe that this is the cause of the DIS Injector failing (since our colleagues have been able to get it to work locally).
Are the any specific port configuration on developer or DMA (and any firewalls between) that needs to be set up for DIS to work?
Jack Perrott-Webb Edited question 17th March 2021
Jamie Stutz [SLC] [DevOps Member]1.18K Posted 11th March 2021 0 Comments
Hi Jack,
I believe the default port is 8004, so if that’s blocked, I could see that causing a problem for you. According to the help when setting up the DMA you can configure the HOST settings as follows:
Host
In this box, enter the IP address or server name of the DataMiner Agent using the following syntax:
https://[IP address or server name]:[Port]/SLNetService
Note:
•Both HTTP and HTTPS are supported.
•Specifying the IP port is optional. Default port: 8004
•Specifying the suffix “/SLNetService” is optional.
For the full help article, you can reference here. Hope this helps!
Jack Perrott-Webb Selected answer as best 17th March 2021
