DataMiner Functionality Evolution and Retirement
Important announcements about the latest changes to DataMiner core functionality and behavior.
ItemCurrent statusDetailFuture status
Jobs appEnd of EngineeringModule is being retired.End of Life to be confirmed
Ticketing appEnd of EngineeringModule is being retired.End of Life to be confirmed
AnnotationsEnd of EngineeringModule is being retired. End of Life as of DataMiner version 10.3.x (Q4 2022)
Legacy Reporter & DashboardsEnd of EngineeringModule is being retired and replaced with the new DataMiner Dashboards app. End of Life as of DataMiner version 10.3.x (Q4 2022)
Web Services API V0End of LifeFrom DataMiner version 10.1.5 onwards, version 0 of the DataMiner Web Services API is disabled. Users will be required to port any reliant applications to use Web Services API V1.End of Life
Overview of statuses
End of EngineeringFeature will no longer be updated, but will still be supported.
End of SupportFeature will no longer be updated and no longer be supported.
End of LifeFeature or compatibility will be removed.
Alarm Squashing
From DataMiner 10.0.12 onwards, alarm squashing can change the behavior of the Alarm Console and help you gain more clarity on your operations.
For more information, see Declutter your alarm tree.
Average Trending Calculation
As of DataMiner 10.1.9, the new average trending calculation feature is enabled by default. This results in the following breaking changes:
  • Some special status trend points are no longer used.
  • In some specific cases, intervals between two average trend points are no longer guaranteed to be constant.
  • The exception values of continuous (non-discrete) parameters are now averaged in a discrete manner.
For more information, see Average trending calculation.
